onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Apr 12, 2005 9:32 am
Are you trying to get this switch to power your high-beams?
If so, it shouldn't be "too" difficult.
Basically, if you look at it, 1 must be ground, 1 is probably power "from" and 1 is power "to" when the button is pressed.
Ground the black 1, provide power to one of the colored ones, and press the button and check w/ a multimeter.
Once you figure that out, the highbeam wire, is 1 of the 3 wires connected to the headlamp. Easiest way may be just to connect it directly (fused if you must or trace it back to where it is in the fuse box). To find the highbeam wire, unplug the harness, turn on your lights, multimeter everything, then turn on your highbeams - the wire that changes voltage is the highbeam wire.
I hope that's what you were looking for.
