Floor Liners
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Toe-Knee
Car: 2009 Nissan Versa
Weather Tech make digital fit floor liner for the Versa. I was about to order a full set for the front rear and cargo area, when I found out that the front only fits the models with automatic transmission. Weather Tech does not make these liners for the manual (the clutch gets in the way).
Where can I get floor liners for my 1.8 6 speeb hatch? Anyone?
Tony
iluvmyVersa08
Car: 2008 Nissan Versa SL Sport
I made my own carpet for the cargo area; dealership wanted too much for it.
nick425
Car: 2008 Versa S
Couldn't you just cut a small corner off to allow the clutch to clear the mat? Use some high grade hook/loop underneath so it doesn't creep up.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
My local Ace Hardware has a large roll of weather resistance material that is $3 per linear foot. You could buy about 5 feet and make a set of mats easily. There are little teeth on the bottom side of the mat that will bite into your carpet to not move around. Use your current mats as a template or cut a rough cardboard shape to trace on the material.
Codelicious
Car: 1989 Nissan 240SX
Auto Zone carries liner that people put on their subwoofer boxes. It's like $10 and I think the sheet is big enough to cover the whole area in the back. It comes in black and gray if anyone is interested.
We redid my friends doors in his Izusu Rodeo with it. Looks great!
JPS48
Car: 2009 Versa SL Hatchback
I believe Weather Tech's claim that they aren't patterned to fit a standard isn't so much a clutch pedal issue as it is the transmission tunnel shape in the standard transmission models, which is slightly narrower and therefore mats for the automatic won't fill the entire floor area.
However, the same applies to the 'Versa' carpet mats that came with the vehicle as it also does to the 'winter mats' that the dealer sells complete with the Versa logo. These winter mats are 'similar' to the Weather Tech's but not the same. However, they were much cheaper, in this market anyway, and seem to do the job.
Return to “Versa Technical Discussions”
