Floor Jack Points - 2020 Altima
General discussion area for the L33-chassis Altima.
Hoffmie
Car: 2020 Nissan Altima
Anyone have a photo or diagram showing where to place a floor jack (not jack that comes with vehicle) to lift front of vehicle so that stands can then be placed? Trying to do my own oil change and can’t believe Nissan won’t make this simple info available.
Not mentioned anywhere in manual. Already check. Many times.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
A is lift points, B is floor jack points. The lift points are the same as the jacking points for the onboard scissor jack.
Hoffmie
Thank you. “B” is likely under plastic covers?
VStar650CL
Technical Expert
No, the sketch isn't the greatest but they want you right at the front of the reinforcement that the subframe gussets bolt to (the funny triangular things). Actually, anyplace near the gusset at the front of that reinforcement is fine. I never use that, I use the body flange pretty much exclusively. If they're fine for putting one corner up on a scissors then they're fine for anything, and they're just about the stiffest part of the whole body.
Return to “6th Generation Altima Sedan (2019+)”
