fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Mon Feb 10, 2003 3:25 pm
eh, its just a jack and stands.stands are pretty similiar across the board, its the jack where kits will differ. expensive kits will have lifts on the plate that pushes it up to the car before you start cranking it down (while other jacks require you to crank it all the way.) Still though, even a reletavly cheap kit will do the job--- just see what you wanna spend and what options you can afford
