robertwb70 »
https://forums.nicoclub.com/robertwb70-u6326.html
Mon Oct 27, 2008 6:41 am
I have a problem and I can't afford trial and error to solve it so I figured I'd come ask the experts first.
Car: 1992 nissan 240sx 5sp 240K miles entirely stock
problem: Car won't re-start more than once every 3-4 hours, doesn't seem to be heat related because you can start it and shut it off 2 seconds later and it won't re-start. When it does this I pull the plugs and they are gas soaked so the next time it wouldn't start I unplugged all the injectors, held the throttle open and it started for about 1 second, then I reconnected the injectors and it started. So it seems to be a fuel problem, I swapped the FPR with another I had and it made no difference so I'm thinking MAF meter or maybe O2 sensor or maybe even a coolant temp sensor but like I said I can't afford trial and error and I'm not 100% sure how to test these parts. The car runs OK when it does start, a little rich but it runs OK, and 2-3 weeks ago I tracked gas mileage and it was getting its usual 28 MPG so it's not a major wear issue I don't think.
Also I should mention that my GF recently put power steering fluid in the crankcase by accident which is when this problem became worse, it did it before that happened also though and it was progressively getting worse. I have drained and flushed the engine oil so that has been taken care of.
