I saw in some old threads I searched thru that you have this same set up. I just have a few questions to make sure im going to do this right the first time.
Ok, on the rear, I see you only need the hub part of the S14 (the part that the (4)19mm bolts bolt on to the spindle) I read that it BOLTS right on the S13 spindle and you retain the S13 suspension and use the same S13 brake caliper but with the S14 5 lug brake disc.
Just want to verify that with you to make sure its right an if thats what you did.
Now for the front. It says ill need the spindle, the hub, strut bolts and ball joint. I'll have to drill my S13 strut holes to fit the S14 strut bolts thru and press out the S13 ball joint and press in the S14 one.
Many people say to press in the S14 ball joint into the S13 LCA, yet this site http://www.nissanperformancema...40sx/says to use the S14 LCA altogether.
Will the S14 front hub part bolt on to the S13 spindle?Or do I have to use the whole S14 front spindle with the hub?What about the LCA? Is that the same as the S13 one?
Sorry for all the questions
