FLOAT HERES THE PICS, IM STUMPED?????ANY HELP WOULD BE SWEET
ca240sxcoupe
Car: 1989 240sx w/ca18det, 1978 Datsun 280z
Again like everyone else i have wiring problems.....sorry....anywho this is the address to my myspace the wires in question are under my pics...its the only way that my camera was letting me post them....but if someone could help by telling me what the blue/red wire needs to be hooked up to that would be cool. it used to be connected to the white dash connector by the ecu before i cut and spliced in the ka connector. and then there is another pic of a plug by the battery that i have nothing to plug into it from my lower harness, its part of the ka body wiring, just wondering if i did something wrong there or not
ca18det240hatch
you should prolly post that adress.........
ca240sxcoupe
crap i dont know why it didnt show, thanks though
http://profile.myspace.com/ind...08943
ca18det240hatch
ok, go to heavy-throttle.com
sr swap faq...follow that for the wiring
if its an 90 240sx....that 4 prong plug may not go where it belongs. there should be a 6 prong plug by your fuse box, and it wont be in use, i think 4 of te wires on it will match the colors of the 4 wires on that one that goes nowhere......you know what to do...join them together again (=
float_6969
Hmm, those wires look like they should go into the ECU. Have you looked closely at the ecu plug and seen if anything is cut?
ca18det240hatch
i cant remember exactly, but i think i had those same ones not connected, and it hasnt affected anything
ca240sxcoupe
hey ca18det240hatch......are you saying that i shouldnt hook those wire that go into the four prong up if they are already in the other plug behind the battery, the ones that were cut and spliced as stated in the swap instrutions.....and its an 89 so same wiring as the 90......and if you could find out for sure if you had the same wires left over
Masterdebater
Car: 1989 nissan 240sx coupe
blue and red wire need to be spliced together with the big black and white by the battery
ca18det240hatch
did you follow the steps in the swap guide on heavy-throttle.com exactly?
ca240sxcoupe
yes.....and im not sure how this happened.....im stumped.........im going to try and drop a battery in it today and see what happens.....wish me luck....
ca240sxcoupe
well i dropped the battery in today and everything inside came on, radio, all dash lights everything, headlights work, and when i turn the key nothing happened......stumped again.....but atleast no smoke or fire....... ..........but still.......stumped
ca18det240hatch
was it auto before?
also....make sure the oval plug with two big wires, that is sitting beside the fuse box is plugged in. Also, can you hear the fuelpump turn on when you turn the key to on?
ca240sxcoupe
it wasnt an auto before, 5spd to 5spd swap....so would i even have that oval plug?
ca240sxcoupe
update: car is now cranking starter turns the motor, but motor doesnt turn....getting closer
Apex
Car: 96 CA S14
I have a similar problem with my S14 and CA18. It will turn over all day but will not fire. It's been that way for a couple of weeks and no one has this specific knowledge to help. So I've been buried in wiring diagrams. Good luck.
ca240sxcoupe
car getting spark?
Apex
Car: 96 CA S14
not yet.
