If your engine is completely assembled, then it's okay for it to be a tad-bit resitant. If you're just referring to your bottom end, I need to know what all you assembled. I don't see a major problem so far, but tell as much as you can about your engine and what you already assembled.ca18det240hatch wrote:Hey, im in the process of building my ca18det...finally.
so i was assembling the engine, and i got the crank in, plastiguaged it...tolerances are excellent. So, i take it apart, put assembly lube on drop in the crank, and retorque it to 40ft/lb which is what the manual says.
The motor spins...but its not zero effort. At 20 ft/lb which i used as my first stage of torqueing, i could spin it wich such ease it would almost keep going...but at 40....its 10% harder to spin...
any pointers or ideas. Thank you guys.
Don't tap it, get a 1/8 BSPT to 1/8NPT adapter. You can them at http://www.mcmaster.comca18det240hatch wrote:now, another question. for those of you that have gone to aftermarket oil pressure guages, did you just tap the hole for the standard fitting or did you get an adaptor.
I don't need you to tell me that . It was an addition to my previous post explaining to him basically what else can cause an engine to be sluggish when rotated, so if when he put on his head and had the same issues, voila. If you like trying to down-play me when I post about something go right ahead, but it was a reason why he asked the people he asked and not you for this information. So please, get a life and stop trying to be wise because your attempts are boring yet stupid and childish and are not in any way useful nor helpful to the atmosphere of the CA forum or NICO.missionsix43 wrote:
And Dee, compression has nothing to do with it when the head is off.
I do not see what the big deal is. He was right about pointing out the compression stroke has nothing to do with anything if the head is off.boost_boy wrote: I don't need you to tell me that . It was an addition to my previous post explaining to him basically what else can cause an engine to be sluggish when rotated, so if when he put on his head and had the same issues, voila. If you like trying to down-play me when I post about something go right ahead, but it was a reason why he asked the people he asked and not you for this information. So please, get a life and stop trying to be wise because your attempts are boring yet stupid and childish and are not in any way useful nor helpful to the atmosphere of the CA forum or NICO.
I hope you have another forum on the web that you can go piss in because I personally am sick of you being disrespectful in this one.
Dee
