float, DEE, help.....again.....
ca18det240hatch
I tryed posting my question in the other thread, but i dont think anybody noticed...need to know for sure...sorry if i am impatient.
i torqued my mains to 40 ft/lb which is what it says in the manual. Is that correct? it just seems low......not sure....
Bwana
Car: Denali
Strangely, that spec seems to be absent from my FSM...
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
boost_boy
I do mine at 36, but the minimum is 33 and the max is 40. You're okay!
Dee
ca18det240hatch
im at 38, 39 somewhere around there.
goood im glad, the engine is assembled minus intake mani and valve covers
theyll be back, tomoro yayyyy
accessories are mounted...and that rb20 alternator seems to work nice.
boost_boy
It's good you're asking questions and allowing us to kinda semi-monitor your build and honestly dude, you're doing a damn good job. As long as you listen and take heed to those who have been where you're trying to go, you'll be just fine.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
unless its from me. i can ruin cold cereal.
float_6969
You can ruin ruin a block of titanium....
r34 gtr
i think i could actually mess up a solid block of titanium before i could ruin cereal. if i had a large block of titanium i would probably try to ruin it.
float_6969
I eat ceral. (weak, I know...)
ca18det240hatch
Yah, thanks alot you guys. As far as im concerned, you cant learn anything unless you ask questions.....or read alot....or both
the only thing in my build that scares me is my ring end gap clearancing....
total seal recommended .010 .020 inch for clearance for that bore range, so i went .020...which is just over factory spec....the only thing that scares me is that i filed them...its all i had. but i rotated the engine quite a bit and had no marks show up. so i think its ok
r34 gtr
you should be fine. unless you really hacked them i wouldnt worry. i done way shadier things and those engines all run fine. in fact...that one i REALLY botched still runs better than it did new!
ca18det240hatch
how did you botch it, what did you do wrong.
r34 gtr
uuuh, name it. dude tried to cut corners by getting me a "running engine" which wasnt even worthy of boat anchor duty. bent pushrods, scored bores, rocks in oil pan, etc.
i made a running engine out of three different ones. the age difference in these engines was about 20 something years. the crank was terribly machined and was about 20thou out in some places, and as little as 7thou in others. i used a wide range of different bearings and shims and whatnot. i honestly didnt expect it to last 10 miles, but its been a year and it absolutely purrs. this wasnt a nissan engine by the way, it was a 258ci jeep.
ca18det240hatch
well i didnt cut any corners with this one, cept that i couldnt find a ring grinding tool ANYWHERE...otherwise i would have bought it, 20$ or 200$, doesnt matter.
i know for a fact my bearing clearances are spot on, plastiguage is my friend, i plastiguaged 3 times total just to make sure hahaha
the only other worry is because of my crappppppy ring compressor, some of them may have moved from their positions a bit, like, spun in the groove so that the gaps arent 180 degrees away from eachther...
i doubt they did.....like theres a 10% chance, but if they did, what would that do.
r34 gtr
you're gonna be fine dude. i did none of that and my engine has sustained many thousands of miles of abuse.
float_6969
Filing the ring ends is fine. Did you file from both ends, or just one?
You'll prob be OK if you did just one side, but both is preferable.
ca18det240hatch
oh i did both in even strokes and everything.
i just hope i have the right clearance. LOL.....damn paranoia
Bwana
Car: Denali
Hey, when building engines attention to detail makes a HUGE difference.
