blownhemi wrote:I've been wondering this for a while, maybe now, that all the great minds are in one place, someone can answer this.
An engine needs fuel and spark, the right amount, at the right time. What exactly about this does the stock ECU not do correctly? What does an aftermarket ECU do different about fuel and spark, that the stock ECU can't do, and that also lets you extract more power from an engine?
Adjust the settings easily with a laptop
Offer more map resolution for finer tuning
Process data faster for quicker reaction
Eliminate performance-robbing things like air flow meters
Let you run crank-fire timing for better high RPM accuracy
Offer multiple schemes for ignition and fuel to include batch and direct fire
Allow the use of multiple injector types with proper resistors
Offer firmware updates for better function
And of course, have a killer theme song
[youtube]
http://www.youtube.com/watch?v=o2Iio8lnYP4[/youtube]
