mirra32 »
https://forums.nicoclub.com/mirra32-u19533.html
Thu Dec 08, 2005 4:25 am
right now the lights will not be H.I.D's because that would add another 400 dollars to the price. i've been driving with the lights so far and light out put is pretty good, but to better the light i'm going to put a 65 watt bulb in there instead. there is a solid cut off when your facing a wall.
so far i just finish with the low beams, next i have to put the high beams and the finish molding with the clear lens covering both of the lights for protection. i'm into functionality more than looks as well so i'm going to make these as good as stock or better. i work at night and i drive out to the country at night so i need a good set of lights.
once i finish my set i'm going to go back and make them easier to use and make try to make them bolt up to cut back on prices
