Flickering lights
Home of the Nissan Cube forum and CubeDriver.com
chantal1965
Car: 2011 Nissan Cube
2011 Nissan Cube
My day lights and night lights ,,,my parking lights and my lights in my radio and heater/ac,, they all flicker,, i changed my battery and my alternator is good,, please help thank you
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The parking/tail lamps and interior illumination are all driven by the same relay inside the IPDM. The interior stuff all grounds through the dimmer inside the combination meter, but the exterior lamps don't. Since those are also flickering, the meter can be eliminated as the possible cause. The exterior lamps also use different wires at the IPDM, so bad contacts or wires can be eliminated for the same reason. That leaves the fuse contacts and the relay. If the fuse contacts are clean and the fuse is good, then your IPDM is shot (the relay is internal and not replaceable).
chantal1965
hello if i take a Ipdm from another nissan cube,, do i have to go and have it reprogram?
VStar650CL
Technical Expert
No, an IPDM from that MY is plug-and-play.
chantal1965
sorry for all the questions
my nissan cube 2011 that starts with a key
i m looking on ebay and i find ipdm the connectors are all the same,,but the numbers ont the part aren t the same
VStar650CL
Technical Expert
Nope, you need the same p/n or a superseding part. NissanPartsDeal.com will generally give you the supersessions if any, just plug in your existing p/n.
chantal1965
i live in quebec canada
part -284B7 1FCOF
i found one ipdm but my part number finishes with F and the one i found finishes with a B,, all the other numbers are the same
VStar650CL
Technical Expert
According to NissanPartsDeal the -1FC0F replaced the -1FC0B. The B fit '09~'14, so even though it's an earlier version, it should work for you. Both of those p/n's were superseded by 284B7-1FC5B, so you could search for that also.
alexspeed
Car: 2009 Nissan Murano SL
Flickering lights are usually caused by faulty electrical. Aside from the alternator, you should also check the voltage regulator.
VStar650CL
Technical Expert
alexspeed wrote:
Thu Sep 09, 2021 4:36 pm
That would be true if all the lights were flickering, but the OP says it's only the park/tails and interior illumination. The alternator (and voltage regulator, which is internal to the alternator) would be affecting everything. The cause has to be specific to those circuits, not the whole car.
Return to “Cube Forum”
