Flex joint size
Iheartjeeps
Car: 1995 Nissan 300ZX Z32
2015 Nissan Frontier Pro4x
2014 Nissan Rogue Paperweight
Need to replace the flex joint on my 14 rogue select and wanted to see if anyone knew off hand what size i needed. 2.25?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If you mean the U-joints, they're staked and not c-clipped. Not a simple process, so be prepared. This is a pretty good vid series performed on a 2010 shaft:
Iheartjeeps
No no lol the flex joint on the exhaust under the oil pan haha. I know the whole section of pipe can be bought as one assembly but I have the ability to weld so I was going to chop and replace it.
VStar650CL
Technical Expert
Lol, flex pipe would have been more descript. :lolling:
Dunno the diameter, but make sure the replacement inner section is corrugated, it really does need to flex!
Iheartjeeps
Sorry boss, i had another question for you...do you know what year they added the "sport" button on the rogue's? my 14 has one but the transmission being from 09-10 the button dosent do anything now, i never paid attention before if it worked or not.
VStar650CL
Technical Expert
The first SM it shows up in is '12.
Iheartjeeps
Ok thanks, so im assuming all the "sport" programming is in the tcu itself which would explain why the sport button isn't responding.
VStar650CL
Technical Expert
Yep, I'm sure that's a firmware function. If the wiring is there then a TCM repro should fix it. Reprogramming doesn't affect the IP Char values stored for the transmission, so the dealership just needs to program it as if it's a new blank unit using the correct ROM ID from the parts catalog. Then your Sport Mode should work again.
Iheartjeeps
so i shouldnt have to drop the pan to get the rom numbers on the valve body? Not familiar with what ip char values is. i'd assume when the reprogram they would clear the deterioration value for the cvt fluid. The reprogram process does that involve dropping the vehicle for the day or is it a pretty simple process with the consult 3. Sorry for all the questions lol.
VStar650CL
Technical Expert
It's pretty simple with the C3+, about 10 minutes once you get it hooked up and ready. The repro only changes the program flash, it leaves the storage flash (deterioration and IP Chars) alone. IP Chars are the solenoid data the TCM uses to run the transmission, they tell the TCM how much current is needed to crack each of the solenoids. That's why you can't just swap used TCM's around with impunity. The IP's for the old and new units probably won't match, and while the transmission may function that way, chances are it won't behave well.
Iheartjeeps
ok Thank you.
Return to “Rogue Forum”
