Flex hose question
pejsa s-13
Car: 91 HardBody, 85 720
i want to run the cxracing kit and i was wondering if i could couple the intercooler piping to the stock tb with something like this
and the reason i want to do this instead of a new intake manifold is the obvious reason pricing
Chris28
Car: 92 s13 KA-T
Wait...what? You don't need a new intake mani just to connect IC piping. If you get the CX Racing kit (which I don't recommend btw) then it should come with intercooler piping.
Don't use that stuff, I'm sure it won't be very boost friendly. Besides, ebay intercoolers usually come with piping and are only like 200 bucks.
WDRacing
Whats with the title? Not very accurate or descriptive at all. I changed it btw.
GODCHSR
Car: 1996 Nissan 240sx
I'm pretty sure that flex pipe would bust under load... besides I don't think it would seal well enough to maintain a tune.
Note: The pic you're looking at is a carb vehicle... doesn't use tuning like us.
WDRacing
That type of tubing only works under vacuum conditions. It's actually used quite often for cold air redirecting and things of that nature. But it can't be used for anything pressurized.
The only type of flex tubing that will work for boost is either rubber, like the factory uses on turbo cars or flex pvc. But I've never seen the pvc come in anything larger then 2", which would work I suppose. Just not something I'd do unless I owned a intercooler of some type already and was operating on basically no budget.
If that's the case we can walk through all kinds of viable options that are cheap and functional.
WD
pejsa s-13
the title was actually pretty acurate d21(truck) z24(engine)
and i im not talking about the flex pipe im talking about the thing thats covering the carb in that pic. connecting to the flex pipe
because here is the throttle body on a d21
but never mind i found what i was looking forthis guy had the same idea as me
WDRacing
Thats called a carb hat, in case that helps your search. That's actually a common mod for the Hard Body
pejsa s-13
yup that was helpfull
know where i can pick one up?
DevilMB3017
Edit:
You're doing this on a truck?
Whoops.
WDRacing
My buddy Kevin has this mod done, I'll email him and ask where he got his or atleast what brand etc.
WD
pejsa s-13
so anyone know where i can get one?
