So I discovered a flat rear driver's side tire last night. Fixing the flat wasn't a difficult DIY project but this warning light on instrument remains ON and won't go away. Tire pressure is 34 psi on all four corners but that repaired tire is still marked red and 'FLAT TIRE - VISIT DEALER' sign is on along with orange triangular warning indicator on top center. Of course I've driven it after the repair, over 30 miles at speeds of up to 75mph.
Owner's manual states; A “Flat-Tire – Visit dealer" warning also appears in the vehicle information display. The chime will only sound at the first indication of a flat tire and the warning light will illuminate continuously. When the flat tire warning is activated, have the system reset and the tire checked and replaced if necessary. It is recommended that you visit an INFINITI retailer for this service. Even if the tire is inflated to the specified COLD tire pressure, the warning light will continue to illuminate until the system is reset. It is recommended that you visit an INFINITI retailer for this service. [8-32 Do-it-yourself]
Really?? You can't fix a simple flat tire on these vehicles? Does anyone know how to reset or clear this warning light?
