Amen! That is the sidewall. No tread there at all.Falkdesigns wrote:Sidewall puncture = you need a new tire.
Much wiser to remove tire and wheel then haul it in.coolman wrote:Can I atleast drive the car 8 miles to a tire shop to get a new tire installed?
I have, all it will do is leak/blow again-if anything happens at all. Would I take it out at 65MPH? No.coolman wrote:Can I atleast drive the car 8 miles to a tire shop to get a new tire installed?Thanks,
Space saver is doggy doo doo, but better than a punctured sidewall for sure.92qatlanta wrote:I know I may be thinking alittle outside the box here, but maybe you could do nothing to the original tire and temporarily drive on.......the spare tire!
-Have you ever driven on a flat tire? -Have you ever driven on a tire with a sidewall puncture?-Have you ever gotten a puncture in the sidewall while you were driving?maxnix wrote:Just remember that all of these brave members advising you to drive on that tire are risking absolutely nothing.
Fair question. When I got to the Nico forum, I didn't know a lot of the TLAs, (Three Letter Acronyms), but I asked and helpfull Nico members would give me the right info. Some that I asked were...coolman wrote:What is TCS?
Brian, if your going to respond to something, try to be helpfull, for once. That tone puts a lot of people off. Not everyone can be as BRILLIANT as you.maxnix wrote:Traction Control System
It's in your Owner's Manual.
CAS = Distributor more or less.louiegz wrote:CAS (Crank Angle Sensor) Which I'm still not sure what it does, but I'm not as much of a mechanic as some of the die hards here.
There appears to be some discrepancy as to the efects of flat/blown tire and its effects on stability. Obviously it ain't good-BUT I saw a segment on Car and Driver T/V where they rigged up a Ford Explorer so that they could instantly deflate/blow the tire at speed (Remember the Firestone controversy). They (Car and Driver) concluded that while the stability was negatively affected that a large contributing factor to roll overs was the driver.Q451990 wrote:Condescending - maybe, but he's right. I lost a sidewall to a road hazzard on a front wheel and ended up with a totaled maxima. I would use the spare, or haul the tire to the shop in an alternate vehichle.
Heath
