Flat Tire HELP!
All things Altima Coupe.
blaze1808
Car: 2008 Nissan Altima Coupe 3.5SE
Intake
Interior/trunk/license plate LED swap
I recently got a flat tire. I'm home, thankfully. I am wondering, if i put fix-a-flat into my ( usually) nitrogen filled tire, can I fill it up with regular air? I just need it to make it to the shop.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
The canned air will be fine but will make it a mess when the shop repairs the tire. You may want to buy an mobile tire pump at the likes of Target/Walmart. They are cheap and work through your cigarette lighter.
blaze1808
Intake
but would that seal it?
seldomseen
blaze1808 wrote:but would that seal it?
It depends on the cause of the flat. In addition, the canned air will affect the tires balance too. Take your car to a shop to repair the flat correctly.
VTMike24
Car: 2008 Altima 3.5 SE 6spd
where is the tire punctured? You can fix a hole in the tread, but not the sidewall. did you drive on the flat tire? if so, you probably damaged the tire and it would be better to replace it.
GPOON
Car: G35 Coupe 2005 (sold)
Altima Coupe 2010 (trade in)
Q50 2.0t Premium 2016
why not put on your spare tire if you are just driving to the shop?
