Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Oct 23, 2006 1:52 pm
Instructions for balancing any tire REQUIRE that the tire is HOT at operating temperature or the balance will change as the tire warms up.
The fallacy in letting a car sit overnight [or an hour in cold weather] then pulling it into shop and balancing tires.
Michelins are often an order of magnitude LESS SENSITIVE due to their more expensive higher quality materials which take longer to cold set and come out of the unbalanced mose fast............what you pay for.
Tire internally tend to operate 30-50F warmer than ambient after a 15-30 minute warm up.
Measure the tire carcass with an IR gun before starting the balance proceedure.
The 9700 pressure roller heats the tire up some but few run it 15 minutes to warm them up. The machine motor would overheat and fail.
Why some many perfect tires on a machine are far from perfect on the road.
