Q45tech wrote:Second gear in a 90Q is 740 rpm per 10 mph so 3,000 rpm would be 40 mph [20 mph?] And 20-22 mph WOT should allow a full downshift to 1st. Does it?
My mistake; it is down around 2000 rpm. (Sorry - but what does WOT stand for?)
Quote »Maybe you are speaking of the typical problem with 2nd gear start where if you are trying to down shift at say 23-25 or higher mph [nothing happens unless you manually pull the gear to 1st.The Q is pretty slow from 23-45/50 mph [till you exceed 3500 rpm] in 2nd.[/quote]
Could be. The flatness is particularly noticable when I slow but do not fully stop at a stop sign, so there is no downshift to first. The car is then really slow pulling away, until the RPMs get up and the power drops in. I have the JWT 1st gear start chip, so from a stop the car picks up pretty well, except for a short lag before the power drops in.
Quote »transmission rebuilds always scare me as few people in the US can do it well -- most work for Nissan/JATCO in Tenn.Measure the 50 mph to 80 mph acceleration [locked in 2nd] with a stop watch [3 times to get an average] and report! [/quote]I'll do that next time I'm out on the freeway and report.
Quote »I am assumming you have had the engine scanned with a Consult to look for codes [knock sensors, etc].You mentioned lots of things but not chain guide replacement when were they done? [/quote]Yes, I have. On chain guides, my car, while a 90, had a new long block put in mid 1994. After much work with Infiniti corporate, we were able to cross the part number of the long block (. . . U02), which is supposed to have the upgraded quides and my car's VIN to determine what was put in. I know, and indeed Infiniti corporate stressed this, while this clearly indicates the proper part, there is no telling without actually looking. This I haven't done.
