FLAT RATE MANUAL
southernmost Q45
Car: 1996 Q45 Pearl White
Anyone on this forum have access to the above?
I would like to know the hours to R & R the sunload sensor on a ''96 Q''
Would also appreciate hearing from anyone who has done this.
Can't imagine much variance from year to year but I do not know that.
Thanks in advance.
InfinitiEric
Me me me me! I have access to it! :gapteeth:
Here's your information:
Just to reiterate what it states above - the replacement will take [0.3] hours or 18 minutes. There was an adjoining diagram attached to the flat rate information which might help you, here's a copy of it:
And welcome to NICO! :wavey:
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
But that is after the dash is apart?
InfinitiEric
Just reporting what it says. :gotme
qship96
Car: 1996 Infiniti Q45
Are you 100% sure the sensor is the problem? I have never heard of one being replaced,as it is just a photocell with no moving parts- if testing it with a multimeter, be sure to have sensor in direct strong sunlight before condemning it.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Why the double post?
The dashboard does not need to be removed, just pull up GENTLY on the windshield defroster grill.
See: http://a8.sphotos.ak.fbcdn.net/hphotos- ... 6255_n.jpg
southernmost Q45
Thanks to all. That should be a great help. I would hate to remove the dash.
I determined it faulty through the 5 step H/A self diagnostics per FSM.
Bright Fl. sun & 3 times repeated results of 25 = Faulty sunload sensor.
Already ordered from Ted.
Thanks again and thanks for the welcome.
southernmost Q45
UPDATE.................
Easy R & R. Just as described. Venerable taped butter knives, perfect tool for this job.
Thanks again.
