clutch_kik »
https://forums.nicoclub.com/clutch-kik-u85357.html
Tue Feb 17, 2009 2:54 pm
If you're talking urethane paint, white doesnt take that long to cover, usually 3 to 5 coats. If you want flat black and you want it last, as in not fade, make sure to do a basecoat/clearcoat setup. You can use any black base coat then use a flat or semi-gloss clear. The one I use is buy PPG, it's called flexed and flat, it's made for bumpers but works on any other part of the car and it a little more flexible than standard clear.
