evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon May 28, 2012 10:01 pm
the hood sensor is right behind the drivers side headlight, should have a little rubber cover on it
you said you have spack and fuel, woudl you mind detailing how you verified this? was the car running before you replaced the cap and rotor? you verified the plugs are in the correct locations ont he cap? (they are labled on the cap), have you checked the ecu for codes?
to check the ignition timing you have to have the car running, the physical timing has to be correct for the ignition timing to be correct, if you set the crank to tdc you can remove the upper timing cover and verify that the cam dots align with the dots on the backing plate (the crank turns twice to each cam rotation so if they don't line up rotate the engine another 360 degrees, and when all the dots are alignes the rotor button should be pointing in the general direction of the #1 contact inside the cap (remember this does not line up with the wires as the cap has some internal routing for the outside pickup points
