dividedhighw »
https://forums.nicoclub.com/dividedhighw-u95262.html
Fri Jan 16, 2009 4:25 am
Welcome to the premier EX forum on the Internet, tquarles and thanks for chiming in!!
Basically kamiguy, any time ICC "decides" it can't operate normally, it will flash.
Other things that prevent ICC from working include:- if you're already too close to another vehicle- if the wipers are ON (other than on the intermittent setting)- if VDC is turned off- if VDC is intervening (e.g. due to tire slippage)- if the SNOW Mode switch is turned on
Now, that's not to say you don't have something that needs servicing ... these are just some conditions under which ICC can legitimately refuse to turn on. Once you convince yourself none of these apply, it's time to turn the problem over to your friendly Infiniti dealer!
HTH,David
