Flashing cluster lights, misfiring & engine shaking..STRANDED IN LIBRARY..help!
AhmadG
Car: 1993 Nissan 240SX Fastback
I'm at a library to post this, my car is in a parking lot like a kilometer away, and I need some advice on wtf to do. Here's what happened:
-Car drove beautifully in the morning, except for the periodic alt. belt squeek.
-Tried teaching a friend how to drive manual......he stalled SEVERAL times, redlined in neutral, hurt the clutch, hurt the transmission......etc. Clutch feels funny, takes some force to put it in first, as if clutch isn't fully disengaged.
-I saw the Antilock, Volt & E-brake lights flashing every 2 seconds all at the same time..... I told him to stop and get out. What does this mean? Check engine light is off, oil pressure is fine, oil level is fine, all the fluids are topped up.
-Car sounded like it had a serious misfiring issue and the engine shakes like crazy under 2.2k, above that its smooth. Going to the back, when its idling rough you can hear BRR BRR BRR BRR from the exhaust, and feel the spaced out puffs of air like its running on 2 cylinders or something.
-My alternator belt was squeeking in the last few weeks, but I never had a charging problem. The belt is still turning the alt., but battery lost a lot of charge when driven with the charging light on for some time to get to the parking lot.
Summary:Friend stalled car several times. Antilock light on, ebrake light on, charge light on and all 3 flashing periodically at the same time (like a diagnostic test or something). Car misfiring like a whore at low rpms (muscle car idle lol). Engine shakes violently until 2k, above that its fine.
After starting it the last time to check belts etc... the ebrake light is off (good), antilock light is stuck on, and charge light flashing.
HELP!!!!!!!!!!!
