Flashing check engine light
volcomskater773
Car: S14
i have a 93 hatch with a dohc swapped into it. we recently replaced the o2 sensor with no problems. checked the ecu and it give me the ok code (55). every now and then the check engine light flashes then goes away. but still code 55. anyone know anything?
GO240
Car: 1990/1/2/3/4/5/7 240sx lol
did you buy an exact replacement or just a bosch universal?
volcomskater773
Car: S14
its a replacement.
volcomskater773
Car: S14
bump
i240sx
Car: 240sx coupe
thanks 4 the banner site...
volcomskater773
Car: S14
bump. for an answer?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
my old car did that a few times, i could never find out why but it never caused any problems
volcomskater773
Car: S14
bump cause its still going on
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
i would also like to know because the vert does the same thing
volcomskater773
Car: S14
i am fairly certain it is showing injector pulse BUT i dont want it there
s13mike91
Car: 91 240sx hatch
i now have the same problem my friend has a 89 240 hatch with a dual cam swapped in it. i have a 91 240sx and my ecu kept blowing my #2 injector out. so i went to his house and he let me used his ecu and when i put it in it shows a check engine light sometimes while driving it. so come to find out when the motor was swapped in my friends car the ecu was never changed out so i'm pretty sure its the single cam ecu causing the check engine light.
volcomskater773
Car: S14
it cant be that tho cause i pulled the ecu from the dual cam car myself. this is getting crazy lol.
s13mike91
Car: 91 240sx hatch
it could be an ecu problem.
volcomskater773
Car: S14
perhaps i do know when someone even bumps it while driving it spits like crazy. almost as the car were... alive lol.
s13mike91
Car: 91 240sx hatch
yeah i was having a bad night that night. and i was turning on a street to go to another friends house i saw the check engine light it made me mad so i kicked it one good time and felt a little more power than normal.
volcomskater773
Car: S14
so mike you dont know anyone with a de for grabs do you? and no idea on the ecu i know the kid who had the car before me duct taped the wires together. gonna tackle with solder this weekend.
wings_s13
Car: 1981 Datsun 280zx
well it washaapping in my s13 and it ended up being the egr val, got that fixed and it was fine so it could be that. it never gave me probs tho just bugged me. hope it helps
wings
s13mike91
Car: 91 240sx hatch
okay so the ecu in my car is for a 91 5spd. i was surprised. my ECU number A11-B44-G70 whats your ecu number i look for exactly your ecu goes too.
volcomskater773
Car: S14
wings_s13 wrote:well it washaapping in my s13 and it ended up being the egr val, got that fixed and it was fine so it could be that. it never gave me probs tho just bugged me. hope it helps
wings
reviving the old post to clear up the problem. i figured it out and wings is right. if you fiddle with the egr (or take it out completely )then it fires up the flashing light no performance loss tho just annoying. if you look at the 180sx cluster its not a check engine light its a muffler lol. hope this helps anyone who has this dilemma.
