sluggoZ »
https://forums.nicoclub.com/sluggoz-u24720.html
Sun Mar 14, 2010 9:00 am
I got these instructions from another forum.For The Airbag Reseting Procedure...you must first change the SRS system to Self-Diagnosis Mode, then back to User Mode to clear the airbag light.
How to Change to Self-Diagnosis Mode:1. Turn ignition switch from OFF to ON.2. With-in 1 second after air bag warning lamp is on for 7 seconds and turns off, turn OFF ignition switch.3. After ignition switch is turned off, wait for more than 3 seconds.4. Repeat steps 1 to 3 TWICE. (perform 3 times in total)5. Turn ignition switch ON again (turn to Diagnosis Mode).
Turn to USER Mode:1. Turn ignition switch to OFF to ON.2. With-in 1 second after airbag warning lamp is on for 7 seconds and turns off, turn OFF the ignition switch.3. After ignition switch is turned OFF, wait for more than 3 seconds.4. Repeat steps 1 to 3 TWICE. (perform 3 times in total)5. Turn ignition switch ON again (Turn to User Mode)
