Flashing airbag light (05 350z)
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Ereth
Car: 2005 Nissan 350Z
I recently put an aftermarket steering wheel without an airbag on my z and I was wondering if it was possible to get the airbag light to turn off, any help is appreciated.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
I'm on my way out to dinner so, so I'll post what I can think right now and do a little research later...
A lot of aftermarket steering wheels come with a resistor you can plug into the ABS leads that go into the airbag. If you don't have/didn't get those you can buy them and connect them to the leads to trick the ABS computer that the steering wheel airbag is in place and working properly, you will 2 of them, 1 for each lead. I want to say that the resistors are 2 ohms, but I'm old and my memory isn't what it used to be. :crazy: After connecting the resistors you should just be able to go through the airbag light reset procedure and be done with the light - at least as far as the steering wheel airbag is concerned.
Welcome to NICO! :badger
Ereth
Thanks a lot, I got the steering wheel used and it came with what I needed to put it on and thats it. I'm sure I'll be able to fix this in no time.
Return to “350z / 370z Technical”
