SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Aug 23, 2008 4:49 pm
There is very little information on these codes and error messages in the ESM. I have seen these codes are cars with <10 miles. My best guess is that they are momentary lapses in communication inside various control units. If picture 2 is the what it shows when you select display control unit, it shows that occasionally there are some lapses in communication. If you look a little harder in there you will be able to find your exact latitude and longitude that the failure happened in, you can also monitor active can circuits which is slightly more relevant than those codes. If you are not having any issues with your electronics I would not worry about it and do not be surprised if the dealer does not find an issue. The numbers that follow the codes are key cycles, it makes it easier for us to match a problem with a related complaint. What prompted the internal inspection?
