evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Apr 06, 2008 7:54 pm
uh..... not so sure it's a good idea to cut into your wiring, a flamethrower kit is really intended for single coil cars, it cuts the voltage and powers a coil you mount int he rear to light the unburnt fuel due to cutting out the main coil, seeing as the Z is COP (coil on plug) it's a bit more complicated, you'd have to cut the main voltage to all the coils and with the electronic;'s it's likely to upset the stock ECU, I highly recmoemd spending your money on something to make you can go fast, or handle better and maybe wheels, rather than rick damage
