adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Sat Sep 01, 2007 9:06 am
heres the low down on coilovers. the cheaper they are, the less quality you'll get.
Megans are ok but are a tad bit bouncy, K sports from what I heard, are crap, teins (I'm assuming your talking about the tein basics) suck even more.
Well the thing about Tein basics (most people won't even consider them as real coilovers) is that they dont come with camber plates like other coilovers do, and their spring rates are horrible as far as performance goes (6/6kg f:r). Theyre there just for the fact of lowering your car.
anyways that's my input on the coil brands you listed. Of yours listed, I'd say Megans are you best bet.
I'd prefer coilovers over spring/ strut combo due to the perfomance (coilovers offer more adjustability and stiffer spring rates)
As far as whats needed, nothing is really needed, but to correct your rear camber (the lower you go, the more neg. camber your rears go), you'll need rear upper control arms (aka RUCAs), fronts are adjusted by camberplates that already come with teh coilovers (assuming you went the coilover route. spring/stut combos dont have camber plates). After you install your coilovers and adjust your RUCAs to your desired specs, get an alignment asap. Lowering your ride doesnt only affect camber, but it also affects caster (i.e your tires will eat up faster).
you don't have to correct your camber if you don't want to, but an alignment is necessary. Contrary to what some people say, camber doesn't wear ties, tow angle does.
