Right on it meant after 2 weeks, returned from being away working.
Bit tired and not too mechanical inclined I was happy to get the new switch out and in in 2 hrs
I had an appt set up with a work shop just in case.
All done and checked the results....none
Checked fuses again....sigh, 1 faulty.
Replaced and brake lights worked, but not the cruise ctrl.
Took all the fuses out and checked......all ok, but now the cruise worked.
I mainly use the pathfinder to pull the boat so the last fuelling was more than a month ago, maybe 2, and I thought I'd re do the fuel cap just in case that caused the service eng lt to be on.
Now the fuel lid wouldn't open. Neither would the back window. Checked fuse and now this one was faulty.
Replaced, all ok now except for the eng lt.
But it comes on usually after towing. Sure it will go away..
I kind of enjoyed doing it all myself. Good learning experience.
