Warpkor wrote:And Flagstaff won. Rolled through Flagstaff yesterday on my way home from Page, AZ. Cool temps and a nice spring day. Then a rather large rock in the middle of the road appears, perhaps the size of a softball or a bit larger, likely volcanic and nasty looking. 70mph, check, vehicle to my right, check and a vehicle behind me, check. With no place to swerve or stomp on the breaks, I had to roll over the rock. Terrible bangs and thumps followed. Stopped just outside of Flag at a rest stop to take a leak and noticed the G was doing the same thing. From the transmission, that is. Gear oil dripping at a steady clip. Expensive tow back to Phoenix and a monster puddle of expensive synthetic gear oil on the garage floor. Glad to see that the transmission hadn't run dry.
I've replaced a few clutches in the past so I though I'd take this task on myself. I just hate having to pay up the wahzoo for some chimp at a $100 an hour to mess things up further with cross threaded bolts and a few missing pieces just for s*** and giggles. The car has a few thousand past 100k miles so I figure that I'll replace the clutch, pressure plate and flywheel and anything else needed at the same time.
The big unknown for me is where to get a new manual transmission case here in Phoenix. I haven't been here two years yet and haven't found all the nifty places for parts. The case is cracked though it's not huge. Perhaps I can take the case in to an experienced metal worker to have it patched.
I need to repair or replace the transmission case.
New clutch, pressure plate, flywheel, pilot, throw-out bearings, etc (I assume I'll be keeping it stock).
Would like to upgrade my jack stands to something very sturdy and not imported from China/Taiwan.
As always. would love to hear your advice and recommendations.
Sorry to hear what happened.
S#it happens.
Last August my 06 G35 with almost 172k miles was going to need between 1 & 2k dollars worth of work including brakes, a differential seal leak, and a intermittent drivers side headlight ballast.
I decided to trade her in for a 2012 G37 S and couldn't be happier. All the bells and whistles including Navigation, back up camera, etc.
My advise is to strongly consider doing the same.
New vehicles come with all new parts and a warranty.
Good luck whatever you decide to do.
Telcoman
