Fixing Wheel Hop, Where should I buy from?
Good240
Car: Cars, Music, Movies
I've read posts from around NICO about what could be causing my new found wheel hop. Straightline wheelspin is now usually jarring and rough. I don't know much about suspension but basically my car doesn't have the resistance it once had to keep the wheel ground under wheelspin. I had the shocks replaced a while back and that fixed wheel hop under throttle around corners. The shocks are still well and stiff but I believe the subframe bushing are no longer holding the tires down to the pavement.
Where should I purchase the items I need and how should I install them? I believe it know the key areas that are exchanged but I'm unfamiliar with the whole process. Any help would be greatly appreciated.
S13240
Check out pdm-racing.com
Good240
Ok, what product exactly should I be buying. I have looked over their site and they cover quite a few things.
Nismo1182
Car: Z06
KCA 349 Rear Nissan Sub-Frame Align and Lock Kit http://www.pdm-racing.com/prod....html
S13240
If it was me...I'd save up for all the damn suspension bushings because my car is a 14 yr old car and all the bushings have gone to crap. I am saving up for all the bushings though...need to replace them all.
Structure240sx
i just put on the whiteline subframe lock kit got rid of all the rear clunking. cant say about wheel hop tho i cant launch very good in an auto
Good240
No clunking or noise... Just jarring wheel hop in a straight line when you sidestep the clutch. I'll look into the sub-frame align and lock kit from whiteline.
Once these arrive will I jack up the car by the differential and start unbolting and replacing every spot that the rear suspension has a bushing?
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
Metal doesnt wear out, costs basically the same, and its not that stiff.... hehe
Go metal, you know you want to!!!
