fixing rust and dents
seng
hi i just got my 89 240 fast back an it has sum rust and dent problems any thoughts on how i can repair this by myself without payin a shop to do it?
Und3rprshUr
Car: My 300Z
Bondo and a scrapper.. make sure you remove all rust and sand down to new bare fresh metal.
Then dependin on size of hole and rust repair using bondo and sand paper.. or grate
seng
Thanks alot Und3rprshUr im on my way to pick the thigns i need up right now ^_^
U12 2NR
some of the dents you can knock out carefully with a rubber mallet, it takes time, but you can get a dent out pretty easy, putting bondo to fill a dents requires your to get it painted. If the dent is really big, don't use bondo. It's probably easier to replace the panel.
