Chaluska »
https://forums.nicoclub.com/chaluska-u25522.html
Tue Jun 09, 2009 8:32 am
You are correct
The plastic trim piece IS part of the sunroof, and cannot be purchased by itself, Best bet is to find a new glass, Replacement is not that hard at all.. I found an entire new sunroof assembly for 50 bucks, and swapped it over.
Hardest part for me was getting the assembly in and out of the car.
If your interested, You can also grab any wheel out of any 95-99 sentra, 95-99 maxima, or practically any nissan of that generation for that matter, the airbag plugs in, and the wheel bolts up.. they all use the 3 bolt turn signal cancel.. I had a 95 maxima wheel on my S14 at first, then i found a mint condition 2006 spec v wheel that i installed.. I still have my horn, airbag, and turn signal cancel, and it looks freakin SEXY.
