Postby
icnuthin »
https://forums.nicoclub.com/icnuthin-u19865.htmlSat Sep 22, 2007 7:47 am
hey everybody i have a hks fmic and was doing a boost leak test and got 5 leaks out of the way and found a small leak in my intercooler. what can i use to fix this hole. something like jbweld?
oh yea and i went through 12 searching pages of fixing this but nothing. i guess i just dont know how to word it out. cause i get nothing when i type in fixing fmic or hole in fmic.
Postby
icnuthin »
https://forums.nicoclub.com/icnuthin-u19865.htmlSat Sep 22, 2007 8:08 am
it is the top right facing the radiator as if something brushed against it and its a little pierced. but its really small like a pin hole and releases air like if i boost leak test to 7 psi then it takes 15 sec to all leak out.
lol I need to do this some time boost drops from anything to 5 psi.... its the intercooler I have stupid sr smic I knew when it had a 2psi drop.
its not too bad if th eholes are small, just use some rtv or jbweld that bia, jb stick is good for radiators and thats basically what an IC is..... just spray some "aluminum" paint on that bad boy and go to town
Postby
Zippy69 »
https://forums.nicoclub.com/zippy69-u73952.htmlThu Sep 27, 2007 10:32 am
Sand the area and J-B weld it. I had a boat motor with a crack in the block at the cylinder and JB'd it and it worked fine , sold it and was running a year later.
Postby
coolbone28 »
https://forums.nicoclub.com/coolbone28-u23573.htmlThu Sep 27, 2007 11:38 am
Man if someone is charging you 80 bucks to fix a hole then either they are retarded or Just flat out trying to rip you off. I got my down pipe fabbed up, had them put o2 sensor bungs on it, and had them weld up a flange for my BOV on my IC piping. ALL that cost me 80. This was just at an exhaust/fabrication shop.
Postby
lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.htmlThu Sep 27, 2007 11:54 am
icnuthin wrote:80 to fix a small pin hole. forget that i just used some quick steel. works like a charm. i basicly rolled it to a size of a be-be and plugged it.
$80!? lol.. wtf.. I got two of my intercooler pipes welded up for $15
