Jookmasta »
https://forums.nicoclub.com/jookmasta-u6633.html
Tue Mar 22, 2005 10:01 am
well sad to say i was in the same boat as luderacer. I pulled off my wheel well plastic guard to switch it out as i had torn up the previous one and what do i see................the upper hot pipe is barely connected to the lower hotpipe
Ding, lightbulb over the head. so i reconnect them and voila, instant gratification with a perfect idle and a lovely purr.
If anyone and i mean anyone has the same issues, look for loose connections. U can easily tell by the "jiggle test". If you try to wiggle either the hot pipe or cold pipe, there should be absolutely no play in the pipes. The hot pipe can jiggle a minute amount if ur using a 90 degree silicone coupling like me but the cold pipe should be firm like balls.
Anyways, im happy and i shall share the rest in a another thread
