More like 4 quick consecutive knocks until it went away after turning my ignition on.
I was unaware of this until I observed myself on our security camera system and heard my engine on the video.
Seriously, I was not too happy about it. Actually, i thought it was normal.
But after viewing security footage every once in awhile, the knocking sound kept bothering me.
Anyways, I finally figured out it was because i've been using the bigger version of the Fram Ultra filter. Because of really good reviews I loved using it lately.
I really wanted this filter to be my Go To filter but not if my Rogue has a rattle at every startup.
After research and vaguely remembering info on it possibly being oil filter related.
I checked a dozen forums for a solution to my dilemma.
They said motorcraft and mopar filters usually solved the problem but those were usually used on vehicles like Ford & Jeep.
Also came across that Mobil and Napa filters would fixed the problem.
I went with the shorter version of the Mobil filter.
My thinking is the smaller the filter the faster the pressure to spread the oil perhaps?
I'm no expert just guessing. Sounded like there was no oil in the upper part of the engine where the lifters were for a few seconds. Seriously, i'm clueless.
Don't know if the longer version of the Fram was the reason I got those knocking sounds either.
Anyways, i am sure the small oem Nissan filters would work too.
Fortunately, the rattle is now gone after unknowingly using the bigger fram oil filters 3-4 times.
Maybe I might try the longer version of the mobil.
Who cares about more surface area for cleaning, i prefer no rattle which is better in my mind.
All that matters, is that this set-up works! Perhaps, i should have used the oem size from the beginning.
Take my advice all new rogue owners out there, instead of doing what i have for a decade with my rogue. Find a filter that does not create startup rattle.
Actually i dont know if this happened the many years I used the longer version of the Bosch Distance Plus since i never really listened to my startup.
Thank god it was not some hydraulic lifter or timing chain tensioner issue.
Or maybe the oil filter drain- back check valve not acting right. Not really sure of the reasons.
But now i know which filter to use.
