Yes, the stock regulator is a 3 bar. Setting one at 4 bar would work, but you wouldn't have 493cc/min injectors, you would have 427cc/min injectors. The reason is, fluid flow through an orifice is proportional to square root of pressure drop (Bernoulli equation). So at 3bar, you have 370cc, at 4 bar, you have 370*sqrt(4/3) = 427cc/min.
At auto performance engineering,
http://www.autoperformanceengineering.com , they have a chart that lists the fuel flow vs. pressure curves. You'd need to use that to determine if you could get enough fuel at the pressure you want...it isn't like the pump just goes kaput at some pressure...the flow decreases with increased pressure so you need to make sure that at the pressure you'll use, you have enough flow.
Suffice it to say, you'll be fine on a Walbro 255lph high pressure pump to do what you are asking.
