fixed overheating, now not starting..
240pav
Car: 1991 240sx sr20det redtop
ok so i got it back from a crummy shop and had to fix overheating issue, it was a fresh rebuild. i got some new toys ( radiator, hoses, water pump and pully set )
i installed everything fine, although the only pully i did was the water pump pully
now it is trying its damndest to crank but wont actually startcould this be a timing issue ??
fuel pressue is good and pump is good. checked injector wires and they were good ( ground and volts )
any help would be great otherwise i have to get rid of it dirt cheap..
thanlks
PapaSmurf2k3
Site Admin
so it cranks continuously but wont start? Have you checked for spark? Did you screw with your distributor at all?
http://www.240sxtech.com to check how to set your dizzy.
240pav
thank u sir i will be checking it out and checking timing again this weekalso got it to start today. its backfiring real bad and i have to keep it revved above 1300 rpms or it dies...
PapaSmurf2k3
Site Admin
for whatever reason, I didn't think you had an SR. Anyway, you might want to ask in the SR forum.
