FIXED MY RIMS!!!!!!!
All things Altima Coupe.
nismogxs21
Car: 08 Altima Coupe 3.5
So as many of you know (or dont) i had bent my last set of rims & it was leaking air. 1 of the rims were bent & 2 of them had curb rash... the rash wasnt nothing too crazii just many scrapes... but the rims were not drivable for a while now...
Took the rims to a shop on friday & got them back the same day
When i first saw them at the shop my eyes lit up!!! :iconeek didnt imagine that they would look brand new again considering he fixed 2 rims for $120 TOTAL!!!!!!!!!!!!!!! :woot: :woot: :woot:
Now the bigger questions spring up... Keep Or Sell?? lol honestly i feel like im definitely keeping
the real question is tho what does every1 have on their back rims for tires??? the rims are 19"
right now i have the g35 18" rims & i rub like crazii when ppl sit in my bak seat or when the cars bounces too much... tires are 245/45/18
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
Keep Keep KEEP!!! they look sick
nismogxs21
lol dats not da question... im keepin them dont worry :rotfl
insaneturbo13
Car: 2009 nissan a/c 2.5se red, medium tint, center console lights, ac vents, avic-u310bt, pioneer sub/amp 800 watts,
those look sick dude! im glad you got them back at an amazing price!
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
yee where u from? n whered u get it done cuz that mad good price i need 4 fixed .... :couch
johnnir3volution
Car: 09 nissan altima
infiniti_lineup wrote:What's the name of the place you went to?? I have a huuuuggee crack in one of my wheels, wonder if they can fix it
Cracked rims would never ride the same
audtatious
nismogxs21 wrote: right now i have the g35 18" rims & i rub like crazii when ppl sit in my bak seat or when the cars bounces too much... tires are 245/45/18
18" G35 rims are +30mm offset which is causing problems along with the tire width. Maybe try 235-40's.
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
Mattv609 wrote:yee where u from? n whered u get it done cuz that mad good price i need 4 fixed .... :couch
Werdddddd I'm with you dude where did you go I need my rear lips cleaned up :facepalm:
nismogxs21
got them fixed at this place call el gato racing/(performance) right off the florida turnpike in kissimmee... check it out on google
u kno im from florida bruh lol im always in ny remember i live in floral park but my cars in fl lol
wat tire size would be best for 19" rims w/ a +40 offset??
wat u do to ur rims bro????
audtatious
nismogxs21 wrote:
audtatious wrote:18" G35 rims are +30mm offset which is causing problems along with the tire width. Maybe try 235-40's.
+40 offset is much different than a +30 offset. 245's may work fine in that configuration. How much of the tire is rubbing and is it rubbing the outside or inside?
nismogxs21
the g rims r flush with the body of the car... i love it that way but da outside to tend to rub
audtatious
I had similar issues with my 2k2 Maxima running the 18" infiniti wheels and 245-40's (Eibach suspension). The main issue is the offset of the rims at +30mm and having tires that are wider. With the Maxima I only scrubbed on the passenger side (even after I bent the lip) and 235-width tires would have probably resolved it. On your Altima that does not look to be the case. 19" rims with +40mm should be fine as long as you use the correct tire to keep the car calibrated.
