Now that you have successfully followed instructions to repair MAF.
Mr Phleps your assignment is:
Measure the restrictions at various points in the air passage as I've been suggesting for about 7 years because your eyes, mind, and a ruler can deceive you.
A series of restrictions are not algebraically additive plus the air flows in, is in sinewave shaped gulps 460 @6900 rpm per second.Luckily you know that the system is being supercharged by earth to 14.7 psi [barometric correction required].
Air speed thru the opening is more important.
http://www.pipingnews.com/online.htm
The answer is <1/4 of a psi [<7.0" H2O] from atmosphere to MAF inputA K&N cone filter will have 2-2.5" H2O from atmosphere to MAF
How much is 4" H2O worth..................4/27.7=0.1444 x 6.8%= 1% at the best case but you give up addition tuning of system to boost highway cruise MPG.
