Fixed cracked leather on 1991 Q45 (pictures)
ti286
Car: 1991 Q45a
It's possible to repair cracked and faded automobile leather as a DIY project. I used a professional kit I purchased myself ($1000+), which I plan to use for my detailing business, but for about $140 and 8 hours of your time, you can restore your leather to like-new condition. Spend an extra $50 for conditioning oil, and it could be even better than new. There are many retailers online who sell DIY kits, but I don't know which to recommend; just do a Google search.
Driver's seat before:https://home.comcast.net/~rrkt...0.JPG
Driver's seat after:https://home.comcast.net/~rrkt...0.JPG
Steering wheel before:https://home.comcast.net/~rrkt...0.JPG
Steering wheel after:https://home.comcast.net/~rrkt...0.JPG
Also, I have found that severely corroded "pie pan" wheels can be repaired on older Qs. First, use a strong acid wheel cleaner and steel wool to scrape the dirt and brake dust out of the spokes. Acid wheel cleaner can be purchased from topoftheline.com. Do not let the acid rest on the wheel for more than 120 seconds without hosing it off! Then scrub the center caps with a green scotch pad and paint them with rattle can paint.
Before:https://home.comcast.net/~rrkt...0.JPG
Afterhttps://home.comcast.net/~rrkt...0.JPG
By the way, the car is for sale. See details here:https://home.comcast.net/~rrkti/q45.htm
I don't intend to sell the car in this particular post, but direct you to this URL to give you an example of a web page format that I have found to be very successful in selling my used cars. Always, always provide as much info and pictures as possible when selling your car. It fetches a lot more interest.
CrimsonQ
Car: Purple People Eater
wow that leather looks incredible!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Wow thats exactly what I would need to make my drivers side seat look perfect...
Did you use leatherique??? Id like to hear more on the actual procedure.
350zQ45a
Car: 350Z, Q45A
The entire process is posted on their website. They have multiple people send in emails on how it was performed, then the owners of leatherique have a detailed section on a jag fix.
Leatherique is the best.
Rex
Car: None
Not to be a jerk, but the console in these 2 pics don't appear to be from the same car??
tkd_q45
Are you ever going to be in the LA (Los Angeles that is) area? I'd love to have the same work done on my Q! BTW - Looks Great!!!!!
ti286
Car: 1991 Q45a
Rex wrote:Not to be a jerk, but the console in these 2 pics don't appear to be from the same car??
Good observation. I bought a used wood dash kit from another Nico member (3rd Q) to replace the old one, which was...garbage.
QShip
Nice job on the leather!
elwesso
2007 BMW M Coupe
ti286 wrote:Good observation. I bought a used wood dash kit from another Nico member (3rd Q) to replace the old one, which was...garbage.
What kit to fix the leather did you use?
kimrober
Car: 1996 Q45t, 2002 Q45
Amazing result!! Could you let us know where did you get the kit from? and what's the name of the kit?Good job man!
3rd Q
ti,That dash looks much better w/your interior than it did w/my burgundy one!Love to hear more details on the leather repair- looks awesome!Paul
DrewQ45
Car: 1990 Infiniti Q45
ti,
I must say that's an amazing difference.
How does it hold up after you sit on it for a while? I'm imagining that the dye would start rubbing off on clothes and the cracks would come back quickly.
Not meaning to be negative, it's just the natural skeptic in me. (Plus I'm secretly jealous)
...Drew....
RobertsnewQ
The PO of my car did that to the steering wheel and it came off pretty soon after. Don't know if it's the same kit. I've been tempted to fix a few spots on my seats too, but I have very little faith that it will work long-term.
ti286
Car: 1991 Q45a
I used a professional's kit from Trimflex Vinyl (cost thousands), but I've looked into Leatherique's products, and for about $150 in parts and eight hours of your time, you could get the same results I got.
I have driven the car 1000 miles in 80 and 90 degree weather, and the dye has not worn off. I have two coats of water-tight sealant laid down over the dye; it's permanent.
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
I saw this online that looks interesting.
http://www.leathermagic.com/Se...rdc=4#
I don't know if it any good but they have a chart to match Infiniti colors.
http://www.leathermagic.com/se...cid=8
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
not the same car look at the steering wheel pics the center consul rear of the shifter is damaged on the befor pic and perfect on the after pic, if it is the same it is a miracle
Rex
Car: None
jamesmost wrote:not the same car look at the steering wheel pics the center consul rear of the shifter is damaged on the befor pic and perfect on the after pic, if it is the same it is a miracle
I offered a similar observation (see above) and he mentioned that he had changed the "wood trim" from an original/crappy kit, to the much better kit you see int he 2nd pic.
elwesso
2007 BMW M Coupe
Helps to read the thread buddy ...
jamesmost
no doubt it is just too good to be true
ti286
Car: 1991 Q45a
Thanks for posting the pictures. Gives some hope for my brother's Q.
Its weird saying "my brother's Q"
FarFetched
Car: Suzuki SV1000S.
Sounds as appealing as Q45 avg 26-29 MPG using ACETONE trick Cheers!
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Has anyone tried the Leatherique on vinyl. Just wondering if it would work since it is water based? Does it rub off and need to be clear coated.
szh
Car: 2018 Tesla Model 3.
Q45denver wrote:Has anyone tried the Leatherique on vinyl. Just wondering if it would work since it is water based? Does it rub off and need to be clear coated.
A few days ago, I ordered the Leatherique basic kit (the rejuvenator and conditioner stuff ... not the dye or repair kit.) It should arrive next week sometime. I will compare it to what I use today (Lexol is the name, I think) and post ...
Z
Death by Mullet
Car: 94 Q45
Man! That seems impossible.... Good job.
Mullet
