Zion8561 wrote:I had the Rubber stop on the clutch pedal crack and fall out and I was just pushing the small switch in by hand for a while so I could start the car. I finnaly bought a 4 pack from Autozone for $1.20 to fix it, and threw the other 3 in the ash tray.
The next week I noticed that my brake lights wouldnt go out and I found another broken stop on the floor pan. Luckily I had the other 3 stops & I was able to fix it in the Sears parking lot. Seems you need to be part contortionist to get to the brake switch rubber stop
Wow, and i thought I was the only one. For my brake switch fix, I used a lil rubber mount off the bottom of a kitchen aplliance and super glued it, lol, still holding till this day. I also had to press the clutch switch by hand for a while. But I used another rubber bump stop foundon the inside door of a toyota corolla, slightly bent the mount and it worked perfect.
