Awesome man. i think i will weld the manifold side flange on that came with the wastegate to replace the 38mm flange that came on the manifold. I noticed that myself and was planning on looking into that. thanks for the advice! also, which port were you using on the synapse wastegate for your boost settings. i think im going to just not use the AEM tru-boost for now and im going to run a line from the compressor of the turbo to the wastegate using port C (hopefully 10psi) because i still have stock injectors. does anyone think that this will be a problem? (I.E. too much boost for stock injectors to handle?) also im using a Z32 MAF and i will have to set the power FC intake settings accordingly.Fibre guy wrote:A question... I have that exact same synapse Waste gate, and i have that same manifold... extensively modified...hehe. But I had to weld a larger flange on it because the seal ring slightly overstepped the flange which would spell leak. Did yours just fit on? oh yeah... I didn't have any boost creep problems on the 30 min warm up and 3-4 good mins. of driving before something went wrong with my wiring.
VERY INTERESTED!!! this sounds like what i need. now, will the condensor fit on an S chasis behind my radiator? ill have to run it on the inner side between the engine and the radiator because i have my fans between the radi and the intercooler. the digital climate control would probably be a PITA to wire in so ill pass on that. and will the lines hood up to where the lines are on an S chasis firewall? if anyone knows, let me know. DFTSILVIA, ill let you know depending on whether this stuff will work or not.dftsilvia wrote:
i have the whole ac system out of my r34 rb25 neo clipi have the stock skyline ac compressor/condenser and all the linesi even have the digital climate control n the harness for iteverything is untouched i'll give u everything minus the climate control for 300 if u want the climate control n everything to make it work figure 200 moremy email is [email protected]
someone sent me a PM on carolina nissans that has " rb A/C Compressor, KA evaporator, and some KA and rb lines all for $100" so i may see whats up with that if i can save a bunch of money. ill still need a condenser, someone local will hook me up with that.dftsilvia wrote:ok cool
i also have all the ac stuff off my s14 so if u have to mix and match some s*** let me know
what kind of compressor is it ? RB or KA?meet07 wrote:^^^^^^I can hook u up. 50 bucks and you can swoop through tomm to pick up. thats the ac compressor if ya need it.
are u serious?!?!?!...........someone had best get on here and do some explaining....sickness14 wrote:UPDATE
Bad News...
I just picked up the newly machined head from the machine shop last night with a bill totalling $498. I went to put the head on this morning and realized it is not the correct head. The intake manifold ports are very different and the overall diameter of the ports is a lot narrower than my previous head. I am in an incredible dilemma and am not happy at all.
I was told this was an R34 Neo head. Can the ports be different on a RB25DE from an RB25DET? The intake manifold from the R34 neo will not bolt onto the head.
I will now need another head, then have it machined, and installed.
ORIGNAL NEO HEAD (R34 GTT RB25DET NEO)
2nd Head
Modified by sickness14 at 9:57 AM 3/14/2009
Modified by sickness14 at 11:46 AM 3/14/2009
Is it bad to have the MAF that close? I can move it if so. I wasnt sure how it would affect the reading of the maf sensor.meet07 wrote:dude what the h&*@.......this car is nothing but bad luck. I knew a freind that had bad luck like this and he would not listen to me when I told him to get rid of it. He had to total it in order to get rid of it. This build has to be up there near 14k including the price of the car. Sell the motor and all components and do a rb26 swap.
I wouldnt do all that grinding with the turbo inlet open and missing valve cover. Isnt that maf sensor to close to the tb????
Good luck. I will make sure to pray for you tonight.
Well, that's a problem too. All the info I could find says this thing was exactly the same as the turbo neo head right down to the springs, and now we can't figure out what the hell it is. The dude that sold it to me said he researched it and found it was the same. What would you be able to sell it as? Best thing I can think of is get $40-$50 for scrap aluminium.KUILLIN_DRIFTER wrote:im with meet07! sell parts and start fresh and buy from a nico sponsor!
Exactly what i think. He's been a great person to deal with and even though i've been through hell with this, he's been nothing but helpful from day one. I would do business with him again anyday. Good news though,KUILLIN_DRIFTER wrote:no worries cj easy mistake and i'm gald to see your going to man up and help out a fellow niconaut to correct the error
Its not the dimensions USPS bills on its the weight of the item... UPS bills on both weight and dimensions and will cost more than USPS.Darius wrote:I agree with Shocker. If you search SAU, there are many RB25 heads out there and they go for around $500 AUD. I assume a machined NEO head would go for about $1000 AUD not $1000 USD. That's HIGH!
Shipping will not be $300. Maybe AUD. It cost like $120 USD to ship the 6boost manifold and that's of a similar dimensions.
I think i've had a dream that went something like that before... LOL That would def. look like something i would do one day if i had a second car. I hate excess wiring. and since i dont have most of the things a normal car would have, theres tons of unplugged connectors everywhere!onepuff wrote:If you need something else to do while you wait for the new head check out this thread. It will keep you busy.
http://zilvia.net/f/tech-talk/....html
