Carl H wrote:its been a while since i've seen your harness but it may be one of the older variants with an external ground...if thats the case there is a ground near the ecu but the main grounds are the ones on the intake manifold.try grounding those and see if that works.
hey carl, i have a question for you man. Ok so when doing the wiring conversion on the S14 harness to RB25 neo: At what point is the engine harness spliced to the chasis harness? Im tring to decide at which point in the S14 FSM the diagrams change over to where i have to use the R34 FSM in decoding the wiring for power in the ECU.
when i got the car, the ECU relay was in the kick panel in the passenger side, just hanging there and there was a red 12ga. wire soldered onto two wires coming from that relay, then into an inline fuse holder in the passenger floor board, literally, and that went into a 0/1 ga wire (soldered 12 ga. into 0/1 ga. ) on the passenger footwell area. I took that wire and put it into my fuse holder that i made, with a 20 amp fuse.
Now, the "SMJ" connector, or however i call it, the long skinny one that plugs in from the Engine harness to the dash/ chasis harness on the passenger side under the dash near the floor with the locking lever... is the ECU harness / and ECU connector entirely from the R34, or is that huge plug from the S14. I may be confusing myself but im really lost now. lol.
Im trying to see where my power is being lost in the harness. Nissan is great for not telling you exactly EVERYTHING that one fuse / wire may control.
Im pretty sure there is some kind of lost ignition signal through out the harness because with symptoms like i have,
-ECU no power, but ecu relay has direct batt power-Turn signals no power with hazards that have direct batt power-Limited power to blower motor / vent selectors
im not quite sure where to look first. When i get to the car tonight, im going to check continuity between the hazard switch and the turn signal switch to see if im getting an ignition signal to turn on the turn signals,
then ill check some more of the ECU power in's and see what im missing and trace them backwards using the schematic from the S14 / RB25 diagrams which will be hell.
UGH!!!
-John
