sickness14 »
https://forums.nicoclub.com/sickness14-u123439.html
Fri May 15, 2009 2:03 pm
Thanks guyss.
to all those who do not already know, this car was built by one person who over heated the motor before i bought it. more people had their hands on this motor than there are crayons in the 64 pack.
It overheated once while driving it home from the seller. I thought it was because the fans werent hooked up, and there was not enough coolant in the system, just like the seller said "its cool out, it'll be fine".
It had a loud ticking in the head when i bought it and i didnt know enough at the time to stay away from it, and wound up buying the car out of excitement of what it was, and the thought of how much money i would save on labor because all of the down time of the
I dissassembled the top half of the motor, and replaced it. literally three times, in effort to clear the ticking noise.
I then upgraded several other various components, tuned it myself, and all was well. the ticking stopped.
4 weeks later... Boom. random failure. had the car towed, dissassembled, and came to a conclusion.
the overheating ruined the bottom end. i also believe, due to the neglect of respect in building a car the correct way and breaking it in the correct way, the previous owner raced the car , untuned, and incorrectly timed. (apparent on youtube video of MY CAR racing a Z06 vette, untuned and running 16.5:1 A/F ratio, like it was when i bought the car.
I solved the intermediate and apparent problem (the ticking) which i thought satisfied all that was wrong, which it didnt. The damage was already done.
And now... Inspection of engine dissassembled shows the following:
-Head is salvageable, but #6 cyl has metal bonded to the outer edge of the head opening around that cyl, only on the two sides of the circle, flat spot is protruding higer than the surface of the head, can be machined. Also appears material got under the valves and is bonded to the valve seats, hopefully the seats can be replaced, or saved.
-head will have new valve seals, valve seats, valve guides installed.
-Piston melted around the top rim, material came loose and melted to inside of head on cyl #6, Piston will need to be replaced. piston rings also need to be replaced
-Block has scuffs on it from piston scraping, but salvageable with machine work
-Rods need to be polished where rod bearings are, due to the bearings overheating and scratching rods, but salvageable with machine work
-Crank has a couple of small scuffs on it, but salvageable with machine work
-All bearings, main and rod, need to be replaced. they all turned purple from overheating and have deep grooves in main bearings
This rebuild will be a long one. I expect several months or more without any updates while i repair my life financially. I have to purchase another car, repay debts, and recover from my $16,000 "investment" nightmare.
When this thing is running again, Im going supra hunting.
Pictures will be coming soon, I never let my nico fans down!
Thank you all for the support. Any guidance / comments are welcome. Please dont say that I "should have" done anything. I dont want to hear it. I DID buy a pile of crap, and i WILL make it into something that many will respect, most of all myself.
-John
Modified by sickness14 at 7:08 AM 6/2/2009
