UPDATE! ordered some new stuff
• Nissan Silvia S15 Helical Limited Slip Differential• Nissan Silvia S15 HLSD 6-bolt Splines
• Topspeed Rear Traction Rods
o Gold Forged Extended Aluminum Wheel Lug Nuts 12x1.25
• BF Goodrich TA KDW2 225/40/18 Front Tires• BF Goodrich TA KDW2 245/40/18 Rear Tires
The Z belongs to a friend of mine
and now for the updated mod list:
Motor '98 R34 GT-T Neo RB25DET (Built RB26 bottom end, Neo RB25 head)
Head• RB25DET Neo replacement head• Valve Job / Set Clearances / Resurface• Tomei Poncam Type-B 260mm Duration, 9.15 Lift
Block• RB26 R33 GTR Crank (longer oil pump drive)• RB26 Forged Rods• RB26 8.5:1 CP Forged Pistons 86.5mm• ARP Fasteners• ACL Bearings
Timing• Greddy Timing Belt• OEM Nissan Timing Belt Tensioner• OEM Nissan Timing Belt Idler Pulley
Oil• OEM Nissan N1 Oil pump• Nismo Oil Catch Can• -4AN oil feed line for turbo• -12AN oil return line for turbo
Fuel• Walbro 255lph fuel pump• Nismo Fuel Pressure Regulator• Z32 TT Fuel Filter
Air Flow• Greddy Intake Manifold• Apexi Power Intake• Hybrid Power (HDi) Intercooler, 3" inlet, 3" outlet• OEM Infinity Q45 Throttle Body• OEM Nissan Z32 TPS• OEM Nissan Z32 MAF• OEM Nissan 91’ Sentra IACV
Turbo / Exhaust• Precision SC44 Turbo (T3/T4 .63 A/R 70mm turbine wheel)• Top Mount Manifold• Synapse 40mm Wastegate w/ dump tube• HKS SSQV ver. 2 Blow Off Valve• Blitz SR20 3" Stainless Steel Downpipe• Resonated 3" Stainless Steel Test Pipe• Apexi N1 Dual Cat-back Exhaust
Cooling• OEM Nissan Water Pump• OEM Nissan Thermostat• Griffin Aluminum Radiator• Flex-a-Lite Dual 12" Pusher E-fans w/ thermostatic relay
Gaskets & Seals• Cosworth 87mm Bore 1.1mm Thickness MLS Metal Head Gasket• Rear main seal• Valve cover gaskets• Intake manifold gasket• Exhaust manifold gasket• Cam seals
Transmission / Drive-train / Mounts• R34 RB25 Pull style clutch 5 speed manual trans• TC&S Sprung 6 puck Kevlar clutch disc• Resurfaced Pressure Plate• Resurfaced Flywheel• Driveshaft Shop Aluminum One Piece Driveshaft.• OEM R33 Cross-member• Syko Performance motor mount kit• Automatic S14 Transmission x-member• Peak Performance Pro Transmission Mount• Nissan Silvia S15 Helical Limited Slip Differential• Nissan Silvia S15 HLSD 6-bolt Splines
Electronics / Engine Management System• Engine harness and gauge cluster calibrated to read correctly by CARL H of charlotte• ER34 Apexi Power-FC Standalone EMS w/ Hand Commander• AEM Tru-Boost Gauge/Controller• AEM Uego Wideband• Battery Trunk Relocation Kit (0/1 Ga. Kit)• OEM Nissan Quest Alternator (140amp)
Suspension• Megan Racing 32-way adj. Street Edition Coilovers w/ camber plates• Battle Version Rear Upper Control Arms• Topspeed Rear Traction Rods• Energy suspension hyper-flex system• Energy suspension differential mount bushings
Brakes• Z32 TT Front 2 Piston Calipers• Z32 TT Front Slotted rotors• Z32 TT Caliper Conversion lines
Wheels• RAYS Engineering Forged 350z Track Edition v.1 wheelso (F) 18x8 +33o (R) 18x8.5 +30o Gold Forged Extended Aluminum Wheel Lug Nuts 12x1.25Tires• BF Goodrich TA KDW2 225/40/18 Front Tires• BF Goodrich TA KDW2 245/40/18 Rear Tires
Exterior/Paint• OEM USDM Corner Lights• OEM SE Front Valance Color Matched
Interior/Audio• Nismo White Ball Shift Knob• Alpine speakers• Alpine MRP-F250 Amp• Pioneer DEH-P4000 Head unit
To Do
Mechanicalo Alignmento suspension adjustmento Bushing Installationo LSD Installationo Injectors o Tune
Interioro Carpeto Radio surround bezel w/ cig. Lighter o A/C controlso Shift boot surroundo Back seats o Visor clips
Exterioro Replace seal on sunroof, back window, cowl, and need new wiperseventually get the whole car painted for baller status <IMG NAME="icon" SRC="
http://images.nicoclub.com/forums/image ... /smile.gif" BORDER="0">
FOR SALE
• 2x (F) Bridgestone Potenza RE 960AS Pole Position 225/45/18
Modified by sickness14 at 11:07 AM 8/15/2009
