Carl H wrote:awesome work man, glad to hear its running under its own power again!nice MIL, on the dash...atleast the wiring is right!
Haha thanks man. The mil is from a sensor code "THRM" on the power FC sensor menu, which i believe to be the traction control or the lack thereof. ive got to figure out how to bypass that , ive read a few different things on skylines aus. about putting a resistor on pin 52 on ecu to ground. not sure if its the same on the neo ecu pin out. any ideas?
-Also, this is kind of funny but all this time ive had the car ive thought the bushings in the rear end were toast because any bumps i would go over the back end would sound like the world was coming to an end. Turns out when i was cleaning out the trunk, i gutted it out pulling all the carpet lining out and i found a BUNCH of tools and garbage lodged in the inner rear quarter panel where the trunk floor ends!!! I found a box of pens, soggy cardboard, 2 c-clamps and a screwdriver all back there. i threw it all away and drove the car.... NO rattling. I already spend $220 in bushings from energy suspension and got a quote of $1k to do all of the cars bushings and an alignment from a chasis shop. Also, on the front end, it was banging around when i went over bumps. i pulled the adjusters off of the coil overs, jacked up the car, and found that the front shocks were LOOSE where they attached to the camber plates. i tightened it all up and now its rock solid. amazing what can be achieved when things are done right!
-John
