I took it apart and it was very clean and the gears were in good conditions. Regardless I sprayed it with some WD-40 and electrical contact spray to see if it would loosen it up a bit. I’ll be putting it back together tomorrow to see if it will work. If not then I’d imagine the servo motor isn’t working, but not entirely sure.DCaff300ZX wrote: ↑Wed Feb 14, 2018 1:55 pmMy odo was also intermittent on my NA, sometimes when resetting the trip meter car mileage would be stuck there for however long until I noticed, or refilled fuel. The trip would affect the entire odo cluster, no mileage would be added until the trip was reset- so point of this is maybe check the trip meter area first for some obstruction or dust/debris accumulation.
I'd check the fsm for schematics and other service related stuff, never been down this road myself but that's where I'd start, along with how-to's and any search info I can find.hueycrewchief wrote: ↑Sun Feb 18, 2018 8:33 amI need some advice. I have a 1990 300zx, non turbo, 5 speed manual 2+2. The speedometer is inop. However, both the odometer and trip meter will function. But neither one is at all accurate. I had the speedometer cluster benched tested and it checked out, ok. I just purchased a speed sensor that mounts on the transmission. Is there any other components I should be looking at?
Many Thanks for your feedback.
